MX95 Thoughts and opinions
TyShawn
Hey fellow forum members. I just wanted to get the take from people who has deployed the MX95 unit? How has it been for you any big issues that you ran across? What I am hoping to avoid is any problems like the random reboot issue that the MX75 is seeing.
13 Replies 13
Mloraditch
We have a good number of them deployed. We do enable AMP/IPS. We do use some content filtering at some clients. Have had no major issues. Albeit we also have a good number of MX75s and have not seen the reboot issue.
RWelch
Have a couple in production environments to include both as edge firewalls and VPN concentrators.  No issue whatsoever.  The customer's hindsight is not going with the MX105 from the aspect of being a boost in client devices.  We have not had any MX75 reboot issues (ever) with any of the many in production environments.
JamesT91
Just to add some more weight to this, we have dozens out there in the wild and as far as I am aware none have experienced the reboot 'panic' issues that the MX75 has.
Inderdeep
MX95 unit is good and i don't see any issues at all.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
SeanW
CarolineS
Meraki Alumni (Retired)
Haha @TyShawn - logged in as the wrong alter-ego? 😄
RWelch
TyShawn
YUP!!!!!! I sure did!! At some point I will delete that account :).
Not using that for multiple competition entries are we? 😉😂
TyShawn
HHAHAHA Naaaa... Long story short I signed up to Meraki with my work account when I started my job. Then years later I started working with M-Go and I had to sign up with a home account. Over time I decided to only maintain  a single account (Need all my post count, kudos, and what in one profile).
TyShawn
Sounds like I have my answer..
Thanks Guys
IvanJukic
Meraki Employee All-Star
Hi @TyShawn ,
Even though you have your answer. "problems like the random reboot issue that the MX75 is seeing." I suggest you raise a case with Meraki Support, so they can run thorough checks.
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
TyShawn
Already done good sir, I even have my replacement unit that has been solid so far but the last unit took months before I saw the issue pop up.
