MX250 WAN Port -SPF Compatibility
jrivano
Hi for all,
Somebody can i help me,
For a MX250 can i install a 1G SFP module in a SFP+ slots of the WAN interface that the equipment has?
Thanks in advanced
Jrivano
You'll see on the MX250 product page (at the bottom) it lists compatible SFP's.
https://meraki.cisco.com/products/appliances/mx250
8 REPLIES 8
AjitKumar
Hi Jrivano,
I do not see a challenge here, we are using 1G SFP's in SFP+ slots for few of our customers.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Adam
Yes that is possible.  I try to avoid doing that when I can just use one of the built-in copper ports but I've done it for sure at sites where I don't have many spare ports.
jrivano
Adam thanks for your response
In my case i need connected with a router of other service provider a WAN Level, i understand what i can only use the WAN ports and the lan ports and the lan ports do not apply.
GiacomoS
Hey all,
You can find complete SFP compatibility on this page:
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
On the right hand we have marked the models compatible with each SFP type.
Hope this helps.
Giacomo
Please keep in mind that what I post here is my personal knowledge and opinion. Don't take anything I say for the Holy Grail, but try and see!
Appreciate who helps and be respectful of every opinion and every solution offered.
Share the love, especially the Meraki one!
i think the point has been missed here, what is being asked is can you use the SFP-1GB-SX in the 10G wan ports, or do you have to use a SFP-10G-SR in those 2 ports? yes the MX250 can take SFP-1GB-SX but can they be used in tho 10G WAN interface on the MX250 rather than the normal ports
yes you can
