MX100 SFP Trunk ports ?
lmatthews
Hey guys. Just received my first Meraki MX100 and it seems pretty cool. The one issue I see is, it looks as it the 2 SFP ports can not be configured as trunk ports.  I found some documents that seem to say the SFP ports are defaulted as trunk ports. Can anyone confirm if the SFP ports are defaulted as trunk ports or can be configured as trunk ports
5 Replies 5
NolanHerring
I don't have any MX100s, but I do have MX84 and the two SFP ports are what I use, and I configured them as trunk.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Awesome.  Do the ports come defaulted  as trunks ports ?
That I don't remember =(
TwitterLinkedIn
If you set "use vlans" at the routing section all (non wan)ports  are trunk by default.
If you dont set this. All are accessports
cwf
Go to Security & SD-WAN>>Addressing and VLANs>>Check the box "Use VLANs>> Per-port VLAN settings will appear with an edit box
