Issue with 1:1 NAT
BAndersonIII
Issue with 1:1 NAT
I'm trying to NAT an address for a server on the Meraki's Subnet, but for some reason, outside clients still only use the original IP address for the server. I need to NAT because some sites have conflicting IP address schema. Is there any reason that this shouldn't work?
As I said, this is set up on a meraki with the 172.30.50.0/24 subnet configured.
Is it not possible for the Meraki to Nat an address that's on it's own Subnet?
That nat to the wan port.
If you need to nat for autovpn this is your option  https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation
2 Replies 2
BAndersonIII
Thank you.
