Hi All,
I would like to see if this works for my current environment.
Our uplink is a fiber access port ran from an ms225 to an mx84 tagged with vlan80. The fiber run plugs in to port 11 via SFP, this port is assigned as an access port tagged with vlan80.
So do I need to assign vlan 80 to both the sfp port 11 and baset port as access ports?
Or do I bring in vlan 80 as a trunk port on 11 then set up the baset port that connects to wan1 as an access port?
Any assistance is appreciated.
Update: I was able to figure this out & it does work, thanks for the solution.
