How to Safely Power Off the MX75 and MX450
Shinichi_K
To safely power off the MX75 and MX450, is it necessary to perform any shutdown operations on the dashboard just before?
It should be fine to simply unplug the power cord, but I could not find any document on this.
Mloraditch
Like most network gear you can just unplug it. There is no shutdown command necessary.
Mloraditch
Shinichi_K
Thank you for your quick response!
BlakeRichardson
The config is stored in the cloud so if the unit did have an issue a factory reset would get you up and running again.
The only thing you will lose with unplugging the device would be any logs that haven't uploaded to the dashboard.
Shinichi_K
Thank you for the additional information! I got it.
