This can work if you have a routed block from the ISP, however that doesn't appear to be the case. If you are not meraki users I would just remove the meraki and connect your sonicwall directly. Probably will have to put it somewhere secure so you can return once you the contract is up and you are able to renegotiate to DIA only.
There may be other solutions but I would operate on this like when FiOs almost always ships a router that is unnecessary, remove it and do your thing the way you want. Might have to turn off some alert emails but I wouldn't think att will care.
