Firewall Rule Hits not updating when using Network Objects
Kev_Almond
Hi All,
I know the Network Objects are in Beta still, but anyone else experienced the random nature of Firewall Rule Hits not updating when the Org is converted to use Network Objects/Groups...?
Seems to be very random where some Orgs we have used Network Objects on do update and some don't.
Cheers
Kev
5 Replies 5
thomasthomsen
Just noticed the same problem here.
Have you tried anything, or contacted support for a solution ?
Kev_Almond
Hi Thomas
Yes have had a Case open with Support for probably 6 months. Whilst the issue appears different across customers, some are impacted and some are not, support have declared this cosmetic in nature so have said it will be fixed in due course - not holding hope of it being sorted quickly though.
Kev
Iridium79
I wouldn’t hold my breath, looks like the development team is pretty much partying with the Ubiquiti developers team.   Still no update on another issue that I have with them for over a year!!!
Kev_Almond
They do respond with updates when chased, but not with a timeframe for completion. So happy they don't ignore the chase, but as you say not getting certain things resolved any time soon.
Cant get my head around a Firewall that can't log Rule Hits, which is classed as cosmetic, rather than a real issue.
Iridium79
Apparently the CDP/LLDP issue with the MX250 and MX450 to them is a cosmetic issue and doesn’t have any real world impact, and won’t be worked on,  that’s just a great answer for a solution I spent a good amount of money.  Never again will I recommend a Meraki solution to a customer.
