Expanding to a 23 bit subnet max instead of 24 bit.
Trunolimit2
I've got a site that is out of IP addresses. It would be impossible to look through 200+ devices and see what is what.
What are the downsides of just increasing this address space to a /23 and doubling the address pool?
just to give you the size and scope of the site this is a residential install with an MX100, 3 MS 320, 3 MS 225, 2 MS 120, and 2 MS42s. And several MRs
We have 5 VLANs running. All /24 but our main Data VLAN is about 90 precent used.
Can I just change the main VLAN to a /23 a new subnet range so that it doesn't overlap with any other VLANS?
Is there anything I should be aware of before making this change?
There is no real downside.
In case you have only 50 devices active, but the scope is 90%full, you could also first look to decrease the dhcp leasetime f.e. if its on 1 day you can put it 8 hours
In case you really have 200+ active devices i would make it a /23 and combine it with a fw upgrade.
DarrenOC
Simply create a new non-overlapping subnet and start moving devices/ports over.
Inderdeep
@Trunolimit2 : I would recommend to take different and new /23 subnet and move devices.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
