Disable SIP ALG [Cisco Meraki MX68CW-WW]
Mad_Dog_82
Hi All,
A VoIP services provided asked to disable SIP ALG on a firewall (Cisco Meraki MX68CW-WW).
The description of the reported issue with VoIP - intermittent speech issues.
I searched similar threads in Meraki community and found this one.
https://community.meraki.com/t5/Security-SD-WAN/Does-anyone-know-how-to-disable-SIP-AGL-in-Cisco-Mer...
However, unlike the case in the thread I found in my case PBX is cloud based running in AWS so I believe no port forwarding is required from outside to inside.
As understand SIP ALG is not implemented in Cisco Meraki hence it cannot be enabled\disabled.
In that thread a buggy firmware was mentioned.
The current version of the device in question is MX 18.211.2.
Two questions:
1. Where I can check the latest available firmware?
2. If it is not a firmware is there anything else I should check on the firewall?
Thanks in advance.
Mad_Dog_82
In my case the issue was on the voice services provider.
7 Replies 7
mwiater
I don't think the MX has a SIP ALG.  However, if your Voice service provider configured your service for TLS, that would ensure that no ALG could possibly impact voice traffic.
You might also consider enabling the standard Traffic Shaping rules under SD-Wan & traffic shaping. Be sure to configure your wan bandwidth correctly in the Uplink section, it's important.
DarrenOC
I’ve installed many an MX on voice networks connected to SIP CUBEs and had no issues. As you’ve already stated SIP ALG isn’t your issue here. Your provider is clutching at straws.  What is the problem being reported by the users? Jittery voice, one way audio?
Mad_Dog_82
Hi All,
Thanks for your replies.
Unfortunately, the VoIp provided hasn't give any specific information regarding the reported issues.
From now, after it was made clear that that SIP ALG is not implemented on Cisco Meraki firewalls and this factor was ruled out the provider will continue investigation on their end.
Yos
I have the same issue with this firewall and was wondering how you resolved
Mad_Dog_82
CarolineS
Community Manager
Community Manager
@Mad_Dog_82 - Thank you very much for following up on this thread! I'm going to mark your reply as the solution since it seems you have found the answer (even if it's not the answer you were hoping for). Cheers!
Caroline S | Community Manager, Cisco Meraki
GIdenJoe
If your voice solution is using regular SIP with regular G711 codec you can even capture and analyse this with wireshark.  You can always perform a packet capture on the LAN side or the WAN side of the MX and then see in the telephony analysis if you are having packet loss or jitter.  You can even playback the audio which is cool.
