Best Practice? Implicit Deny
Daniel24
I have just recently switched over to MXs for Firewalls. I assume like most firewalls its recommended to have an implicit deny as your last firewall rule? Trying to plan for any unplanned impact would this impact any connectivity with Meraki switches, AP's, camera's etc from their connection to the cloud.
12 Replies 12
RWelch
By default, the rule already exists.
RWelch
MX Firewall Settings
Using Layer 3 Firewall Rules
Creating a Layer 7 Firewall Rule
DarrenOC
That’s the implicit deny inbound rule.
By default, outbound everything is allowed.
I would suggest that you configure your outbound rules as required with a final Deny Any Any at the end.
Mloraditch
If you want a deny deny any on your outbound rules, you would have to program rules allowing your meraki devices to connect before that deny.
This is the documentation for that: https://documentation.meraki.com/General_Administration/Other_Topics/Upstream_Firewall_Rules_for_Clo...
GreenMan
Absolutely correct for anything downstream of the MX;   Meraki switches, access points, cameras etc.  In my experience the MX will permit anything that it relies on itself, by way of comms with Dashboard resources.
As pointed out by others;   by default all traffic is permitted between VLANs by the MX and from inside VLANs outbound towards the Internet.
Note that if you're using VPN / SD-WAN,  the firewall rules that affect in-tunnel outbound traffic are controlled under the Org-wide element of the Security & SD-WAN > Site-to-site VPN configuration.   By default all traffic within these tunnels is permitted, for VLANs which are VPN-enabled.
BlakeRichardson
For security reasons I would always have an implicit  deny rule, as mentioned inbound is enabled by default but I would be adding an outbound rule as well.
Interesting question.
For small to medium sized companies I rely on content filtering and IPS, and don't have an explicit deny.  I'll often have no firewall rules.
For medium to large companies I have explicit rules for everything and add a default deny.
AllenS
How do I enable IPv4 inbound rules? My dashboard only shows a 6 (IPv6) icon for inbound rules. Below that all I have is outbound rules.
GreenMan
To take NAT into account, for inbound you have to use a slightly different set of tools:   https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
AllenS
Sounds good. Thank you GreenMan and GldenJoe! I'm still learning obviously. I'm still curious why there are IPv6 inbound rules and not IPv4. Is this because NAT and Port Forwarding doesn't support IPv6 yet? I assume then there is an Implicit Deny on all incoming IPv4 traffic. I have used NAT or Port Forwarding to allow specific traffic in. Thanks again for your replies and confirmation.
GIdenJoe
As GreenMan already brought up:
If you are using regular NAT from LAN to WAN then inbound is blocked by how NAT works.
So the way you allow inbound connections is by setting the Port Forwarding rules a bit lower on that same page.
You can use the regular port forwards if you want your appliance IP or virtual IP (if you have an HA pair) to be the destination of the inbound packet.
You can use the 1:1 or 1:Many NAT rules if you have another IP in the SAME SUBNET as the MX appliance IP to be used as destination.
GreenMan
I'm not in PM but my take would be;   IPv4 requires NAT - there aren't enough addresses to give each device its own public address.   IPv6 was designed to allow every device it's own address, so no NAT required.
