Config backup
rulezzz
Config backup
Hello there.
We are going to apply important changes on our Meraki MX100 (create some VLANS ) and I like to know if its possible to make a offline backup or run a rollback in case of something go wrong. Thanks.
10 Replies 10
BlakeRichardson
@rulezzz Sorry but Meraki is 100% cloud based. You will just have to make a note of what changes you make.
you could prepare a script to undo you changes using the API.
Meraki should make some kind of snapshot/save state where you can revert back to.
BlakeRichardson
@ww Sounds like the perfect idea for using the make a wish feature.
I haven't used it for a while, but quite some time ago I wrote this script to doing offline backups/restore.
http://www.ifm.net.nz/cookbooks/meraki-backup.html
What I would personally do is just copy the network to a new one.  Make the changes.  If you need to rollback just move the MX to the new network, and delete the original.
Ahoste
Hi Philip,
I'm trying to perform the backup via the script but i'm running into a problem.
First i had to go use Pycharm since in commandline it couldn't find the meraki-sdk, so using pyCharm fixed that issue.
Now when I run the script with all necessary modules installed i get 2 errors:
Traceback (most recent call last):
File "meraki-backup.py", line 209, in <module>
orgid=get_org_id(meraki,args.orgName)
File "meraki-backup.py", line 33, in get_org_id
result = meraki.organizations.get_organizations()
File "/Users/at-mbp-52/PycharmProjects/Meraki/venv/lib/python3.7/site-packages/meraki_sdk/controllers/organizations_controller.py", line 50, in get_organizations
self.validate_response(_context)
File "/Users/at-mbp-52/PycharmProjects/Meraki/venv/lib/python3.7/site-packages/meraki_sdk/controllers/base_controller.py", line 94, in validate_response
raise APIException('HTTP response not OK.', context)
meraki_sdk.exceptions.api_exception.APIException: HTTP response not OK.
Any idea,
Already want to thank you for the script tho!
Cheers
Aaron
Hi @Ahoste .  This means it is failing to retrieve a list of organisations that you have access to.
Are you sure the API key you are using is correct?
Does the API key belong to an organisation admin?
Ahoste
Hi Philip,
thank you for the reply.
The API key in the .merkai.env file is correct, this was my first thought too and I revoked the key and even created a new one but same error.
The API key does belong to an admin account with "organization" privilige.
Cheers
Ahoste
The call to get the list of organisations is failing.  It's a pretty basic call that one.  It doesn't even have any parameters.
Are you sure the account being used is a Meraki organisation admin?
Are you sure API access is enable to the organisation?
DarrenOC
You could use the Meraki dashboard change log to reference what changes you made.
https://documentation.meraki.com/zGeneral_Administration/Organizations_and_Networks/Organization_Men...
