Client VPN Pool?
jon1
Client VPN Pool?
After enabling Client VPN and adding a subnet, do I have to configure a DHCP pool for the VPN users?
Or is this automagicly done?
WadeAlsup
Hi @jon1
No need for a DHCP pool to be setup, as it is indeed "automagicly" done. The users session will receive an address within that subnet when they connect. You'll then see them show up in Network-wide > Clients.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
1 Reply 1
WadeAlsup
Hi @jon1
