Demo/trial environment for MX
FRanky
We would like to make a 30 day trial with two MX gears with Advanced Security license.
q1: We hope this is a possible trial we would like to make?
q2: Will we have an Administrator with Full access to the Meraki dashboard?
q3: How many users can we declare. Is there any limitation in this area?
q4: Is there any other rectrictions/limitations, regarding this Demo environment?
q5: is there a checklist of what we should prepare before interacting with the Meraki Support?
q1: Yes, you can pretty much request everything you want from the smallest to the biggest box.  You start at this URL:
https://meraki.cisco.com/form/trial
q2: Yes you will have full administrative access.  In fact you will have to create your own Organization (a Meraki Dashboard concept) to put the trial kit into.
q3: Only Systems Manager has a user limit.  Other devices are only limited by the number of ports (such as a 24 port switch) or CPU power (don't try and put 1,000 users on an MX65 and hope to get a good trial).
q4: There is no restrictions in the demo environment to do with trial gear.
q5: You will most likely be setting up the environment yourself.  You should know the normal things, IP addresses, etc.
1 Reply 1
