- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Clear DHCP leases - MX84
May I know if there is a way to clear out the DHCP Leases in a certain VLAN?
I configured static IP addresses but their previous addresses are still there in the dashboard.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I don't know the answer. You could try turning DHCP off and then back on again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I believe as soon as the client disconnects and reconnects to the network it will go through the DHCP process again. At that point they will receive the newly assigned static address. If they try to renew the lease I think the DHCP server will refuse and assign them the static IP address too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have tried it but it seems it does not work 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Every time I'm in a situation where I need to clear a DHCP lease on Meraki, I hit this button so hard...
There is no way (that I know of) to clear a DHCP lease manually in Meraki. Best is to lower lease time, in the DHCP server, and wait for the leases to renew, to the shorter lease time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I think that is the "wish button"?
Well, I will check your suggestion. Hopefully later on the update, they will have that feature.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@jvelasco wrote:
Hi Brecht,
Hmm well that's annoying. Good to know.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the tip 🙂 I will try it now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@PhilipDAth wrote:I don't know the answer. You could try turning DHCP off and then back on again.
This has worked for me in the past. After you turn off DHCP for that subnet, wait about 5 minutes, then turn it back on. When you turn it back on, all your previous settings are still there so it's not as painful as it seems.
Not optimal, but it works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Todd
How do I turn off Dhcp for the subnet?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Security & SD-WAN -> DHCP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I agree! That seems to be the only quick fix for a saturated DHCP pool.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Set the DHCP lease Time to 30 minutes in the evening when everyone leaves and wait.. That's how I handle this.
Cheers
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I've done two options, setting it at 30 minutes and then reboot. At last, it renews all leases.
But I think the Cisco Meraki must do something about this because it is really important.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Looks like they patched that out?
We read your comment and decided to try it. We were joking that only the new leases would get the shortened lease time. We thought that was a hysterical idea. Then it turns out that's what happened. A lot less funny than we thought...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
is there any development going on for this issue? Manually changing dhcp leases to 30 min at the eod is not the ultimate solution. I hope there would be a select and delete option somewhere for removing dhcp leases.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It seems like every time I look up how to do something in Meraki, the answer is you can't. Why do people sell this junk?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@jvelasco wrote:Hi,
Thanks!
Hi @jvelasco,
A 'button' to clear DHCP Leases from dashboard is certainly a feature request at this time point in time as others have commented.
However, there is a way to clear the DHCP Leases on a VLAN without having to reboot the appliance by following these steps:
- Create a DHCP Reservation on the VLAN that blocks out the entire DHCP range
- Save the configuration and let MX downloads it (might take a minute or two)
- Clear the DHCP Reservation and save the configuration again
Hope this helps, if you are still having trouble, I would recommend reach out to support (that's whom I got this info from). You can find support information from dashboard under Help > Get Help.
Cheers,
-Alex
Please mark it as a solution if solved your issue so others can benefit from it 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Meraki Dashboard used to have that option under Monitor -> Appliance Status -> Tools, but somehow they took that away. I've put in feature request for many times, but I still do not see that option. I've done set lease time, created and removed dhcp reservation scope, but it did not work like the way I want. This's very annoyed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This seems like a work-around at best. I hope this "feature" makes it to Meraki.
I try to talk up Meraki when I can, but things like this makes it really difficult.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
zcsdfsfsdf
@AlexC wrote:
@jvelasco wrote:Hi,
Thanks!Hi @jvelasco,
Cheers,
-Alex
UPDATE FOR ANYONE THAT MIGHT RUN INTO THIS
I found this thread because I had to do this for a VOIP rollout.
I repeated these steps -
- Decreased the DHCP Lease Time to 30 minutes
- Clear the DHCP Reservation that blocks out the entire DHCP range
- Save the configuration again
It seemed to work at first. All client DHCP leases were removed from the dash... except they some came back with the original entries. All of the phones are still advertising that their lease time will expire in 20+ hours. Effectively maintaining the lease time they originally had.
Not sure if this is because they're VOIP endpoints, but it only half worked.
The machines on the same VLAN cleared out their DHCP leases and were on the new 30 minute lease time, the phones were not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This worked like a charm, the support tech wasn't aware of this technique! Thanks Meraki Community!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Batch Imaging and deploying 75 computers caused pool to fill up. Count me as one more vote for a method to manually clear inactive DHCP leases.
T-800
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just "Make a wish" on the DHCP configuration page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can perform the reset on MX to clear the DHCP lease. I just did it on my Z3 and it worked.
Please take a note that there will be a down time if you reset the MX.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I realize this is an older post. But wanted to update in case anyone else was running into this. This worked for me.
I put Fixed IP assignment in using the IP address that I wanted to release and save that.
It took it out of the lease then I removed the Fixed IP saved again.
the computer was able to DHCP the address.
Hope this works for others.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Nice work-around S_Tech. I would still very much like to see a simple way to remove a lease, such as a column with an "x" to the right of each entry on the DHCP Lease table, and/or a clear all type option. Even my cheap little TP-Link router has this feature. Where is that wish button?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Amen brother! I was just thinking that as well. Some of those nice to haves you can get in a Linksys gaming router or TP-Link seem to have fallen through the cracks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I just had the same issue. Rebooting and turning DHCP off for 5 minutes did NOT clear the DHCP leases. What did work was expanding the DHCP Reservation range temporarily and it cleared the DHCP leases in the Reserved range like the example below.
