Hi there,
We're using a Cisco Meraki MX75 router with a dual ISP configuration:
- Primary ISP: 200/200 Mbps (Active)
- Secondary ISP: 50/50 Mbps (Ready)
We're planning to permanently disconnect the primary ISP and rely solely on the secondary.
My question is: When the primary ISP is disconnected, will the Meraki dashboard automatically switch traffic to the secondary line, or will we need to manually designate it as the primary?
Thanks in advance for your help!
