CPU utilization on your MX!
Want to find out how your MX is performing? Make sure you are running our latest beta and find out under Organization -> Summary report and select "View new version".
8 REPLIES 8
Re: CPU load on your MX!
I assume the Usage% is the CPU usage?  You may want to add the "CPU" bit to the interface, otherwise folk might think it is a different sort of utilisiation (memory?, bandwidth?, time connected?)
Nice to see in there though, as it helps spot heavily used devices.
#swagplease
+1 for renaming this to "CPU utilisation" - Highly misleading otherwise.
@BillV
Ill bring this up tomorrow with our Dashboard team.
Re: CPU utilization on your MX!
Good feature, but the graph timing bug is still present.  Look at the usage summary versus utilization - it's off by a few hours. I reported this confirmed bug awhile ago via open/closed case.
Nice feature, I've often wondered if/how I could see this info, was curious about the load on my MXs.
+1 for renaming this to "CPU utilisation". Any chance of getting a memory utilisation graph too?
And it looks like the graph timing bug I mentioned above has been resolved too.
This is great! Will there be real-time reporting in the future?
