Backup WAN Status Alert
archedmeerkat
Any plans to add alerting on backup WAN going down? There is an alert if primary fails over to backup, but wanted to find a more proactive way to find backup WAN links going down rather than logging in to find out when we need to fail over.
I guess not.
The options now are:
You can get a alert of status change with meraki insight.
You could use the api to build something yourself.
3 REPLIES 3
I guess not.
Dunky
Agreed, we use Meraki Insight to provide these alerts.
It's also great in alerting to packet loss (we then check against a number of ping destinations to confirm that it is genuine loss on the circuit and not to a specific dst IP that is defined in the SW-WAN & traffic shaping config in the dashboard for that MX).
Tough to justify getting the Insight license just for this. Seems like it wouldn't be a hard lift for Cisco to add an alert for this, but just my opinion. They already show the status in the GUI, can alert on switch ports being up/down, and can alert on the primary uplink.
Will probably either just ping it or use the api to get status periodically.
Thanks!
