Can I create an IP addresses group for Layer 3 Firewall rule?
Mad_Dog_82
Hi All,
Referring to this article https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Firewall_Settings#:~:text=The%20...
It says for Layer 3 Firewall outbound rule, multiple comma separated IP addresses can be added as destination.
What if I need to add say 20 addresses and the number of addresses will grow month by month?
Can I create an IP addresses group and refer to that group in the Destination field?
Thanks in advance.
Brash
You can certainly do multiple comma separated IP addresses in the L3 firewall rules.
However for your scenario where there are 20+ addresses, you may want to look at using policy objects to group them.
Network Objects Configuration Guide - Cisco Meraki Documentation
Brash
Mad_Dog_82
Hi @Brash
Thanks for your reply.
Just wondering if the highlighted rule already blocks all outbound traffic?
Otherwise I don't understand what it is for.
Thanks.
Brash
I'm not actually sure. I don't think I've ever seen a rule before that's all blank. I would have assumed the dashboard wouldn't let you save it.
Typically a block all outbound traffic rule would have "Any" for all of the source and destination IP's and Ports.
That rule is malformed.
