AutoVPN to Umbrella
AVC
AutoVPN to Umbrella
Hi
We recently tried an AutoVPN to Umbrella, to tunnel all our internet traffic.  Long story short, we had a few problems, and had to roll back.
Once the AutoVPN was removed, it left 2 unknown peers on our MX's.
Does anyone have any idea how to remove them (in case it matters, we use templates for our sites).
5 Replies 5
Have you tried this options?
AVC
Unfortunately, it isn't a non Meraki VPN Peer so it isn't listed there.  It was auto created with Cloud on-ramp, but when you remove the deployment, it leaves behind these....which I cannot find a way to remove.
Did you remove all Umbrella settings?
Anyway, I suggest you open a support case.
Did you wait 24h? And then put the vpn status on: for the last day
