AnyConnect SAML Group Policy assignment
Ruben2
Does anyone know of a way to assign a group policy to a VPN Session via SAML Authentication?
With radius Authentication you can pass back an attribute that would put the VPN Session into a Group Policy.
Is this possible with SAML Authentication as well?
9 REPLIES 9
Inderdeep
@Ruben2 : check this out
https://documentation.meraki.com/MX/AnyConnect_on_the_MX_Appliance/Authentication
Regards/Inder
www.thenetworkdna.com
You can't do it ... yet.
Is this still the case?
It is still the case.
joaro
@PhilipDAth
Do you know if there is an update to this?
It is still a work in progress.
".... yet" ... have you heard anything about this being talked about ? 🙂
Alas it is still a work in progress.
thomasthomsen
have anyone noticed that this (Group Policy) does not even work statically with anyconnect and SAML ?
I just tested with a customer, and the static Group policy in the config (at the very bottom of the page) does nothing.
It works fine in non-SAML ... how strange.
