Addressing and VLAN
SD-WAN1
Addressing and VLAN
Can I configure same addressing VLAN, switch port configuration to two different store networks?
But at the level of control and organization it is not a good practice and in the future it avoids several headaches, without the need to do NAT if the two networks need to communicate.
You can, doesn't mean you should.
No, you cannot have the same address from the same subnet in different VLANs.
They must be different addresses on different subnets.
you can have the same subnet in every network.
but you cant use the same subnet if you want them to use the vpn.
