Device are already in use Error - When adding new device
Jmathew
While trying to add a new MX device to a dashboard (Internal Testing) I am getting the following Error.
2 Replies 2
If its new, Contact meraki support
If you bought it 2nd hand contact previous owner, to unclaim the device
KathleenJ
WW gave you the correct advice. If you bought it new reach out to either your reseller or Meraki support. If it was purchased second hand you need to contact the seller and ask them to unclaim the item from their dashboard.
Here is a KB that provides information on unclaiming the device.
