User Data Privacy in Supervised iOS
Aryan
Hi
I am going to receive a supervised iPhone 12 mini from my employer. I want to know what user data can be accessed by the IT? Can they access photos, whatsapp chats, emails, messages which are in my iphone?
Thanks!
Aryan
EncinitasMatt
An MDM like Meraki System's Manager only controls certain settings and app installations.  Your employer can not remotely access any user or app data.  They also can not remotely view your screen.  But they will be able to tell what apps are installed, if they allow you to install your own apps that is.
If they have physical possession of the iPhone, then they can clear your lock code and get full access to your device and data.
8 Replies 8
EncinitasMatt
Aryan
Hi
Thanks a lot for your reply. Is there any document by apple which shows details of what all can be see by IT in supervised iphone?
Thanks again.
tinkushal
HakanTurkmen
What if iphone mail address also has been set as company outlook address, then can IT department monitor or reach somehow to my personal data like messages, photos, special mails and etc.?
PaulF
Meraki Employee All-Star
Hi There. So, firstly, you can browse through here: https://developer.apple.com/documentation/devicemanagement/commands_and_queries to determine what your employer can and cannot see
However, keeping this much more simpler.... photos, whatsapp chats, emails, messages are NOT available to any MDM. This is the user data most likely to be available
Persistent device IDs (serial number, MAC address, IMEI)
Phone data (amount of data used, phone number, IMSI / ICCID, etc)
Location
apps installed. They cannot see if these are in use, however
Profiles installed
Certificates installed
If you are worried about any of the above, I suggest you have a conversation with your employer and discuss your concerns. MDM has been around for nearly 20 years and is used by millions of people around the word. It cannot be used for getting access to your personal data. And it was never intended to do so.
HakanTurkmen
Hi PaulF, than you very much to your comments about my privacy concerns...
I wonder if they can reach to my iCloud since the mail address of iphone is also my company mail address?
PaulF
No. They can’t. And you can change your iCloud account email address at any time.
BlakeRichardson
@Aryan  If you are concerned about your employer being able to see whats on the device I suggest you only use the device for business reasons and get a seperate personal device if you are that concerned.
It's possible they could have the device tied to a content filtering system so that web traffic is monitored even if you are working remotely.
Aryan
Thanks for your reply. Do you mean like a vpn installed on phone?
