System Manager Monitor SSID
dbelliss
I see on System Manager in the Manage Device tab, there is a heading for SSID. I am assuming this displayed the name of the Wifi, however I cannot get it to show on my devices. Is there any special setting I need to enable for this?
I am using iPads on iOS 12.3.
alexis_cazalaa
Meraki SM app must be installed and running on the target devices
alexis_cazalaa
Network-dad
Are your devices in DEP and do they have a supervised profile? If they are not the SSID setting will not be enforced.
WiFi
WiFi settings can be used to push out a wireless profile to your managed devices. Some example use cases for this feature are:
  • Providing an Internet connection for your devices, but do not want to explicitly provide the SSID name or credentials to the end-user.
  • Pushing out WPA2-Enterprise WiFI profiles with 802.1X authentication (EAP-MSCHAPv2, EAP-TLS, etc.) This can be further configured with "Trusted Certificates" that you upload, utilizing the "Credentials" feature described below
Dakota Snow | Network-dad Linkdedin
CMNO | A+ | ECMS2
Check out The Bearded I.T. Dad onThe Bearded I.T. DadThe Bearded I.T. Dad
It may not be enforced, but the SSID will be added.  Ditto on Android.
