Setting Android wallpaper issues
BlakeRichardson
As the title says I am trying to set the wallpaper on a couple of Android devices using the wallpaper payload, I have filled out the URLand tested that the image at that URL is indeed available but nothing is happening on the device, the dashboard shows the profile has updated successfully.
SM Documentation is very light around Android devices and a Google search brings up nothing.
ConnorL
Meraki Employee All-Star
Hey @BlakeRichardson ,
We're aware with an issue occurring sometimes when using a HTTPS URL, you may see the error message "Android Wallpaper - System wallpaper image URL is not valid: An error occurred." This is being worked on now by Engineering and should be resolved shortly.
Alternatively, using a HTTP URL may result in the device using the default background. Do drop me a DM with the case # or link to your SM profile so I can take a look if you're using HTTPS and the profile has saved correctly.
Cheers,
Connor
BlakeRichardson
The lock screen message part of the payload works.
GreenMan
Meraki Alumni (Retired)
Support case?
ConnorL
Cheers,
Connor
BlakeRichardson
Thanks @ConnorL  that worked a treat, I was using HTTP but changed to HTTPS and is working now.
It would be great to have some documentation around Android settings and the best way to configure them. Coming from managing iOS devices to recently including some Android I am finding documentation for Android somewhat lacking.
