ADE & Azure AD User authentication
beks88_
Hi all,
is it now possible to use Azure AD for user authentication on SM?
The initial document still says, it's not supported (Feb 2023)
https://documentation.meraki.com/SM/Device_Enrollment/SM_Enrollment_Authentication
Another document (under User management) let us assume it is indeed supported (Jun 2022)
https://documentation.meraki.com/SM/Deployment_Guides/Apple_User_Enrollment_Deployment_Guide
In this thread this part got also a bit discussed and at this time the first document was older than the second one.
https://community.meraki.com/t5/Mobile-Device-Management/Smartphone-enrolment-Apple/m-p/160251#M9599
What is now accurate?
Systems Manager enthusiast
PaulF
The way to achieve this is to use, one creating a NEW ADE profile, is to use the Enrollment Redirect URL
If you've got Enrollment Auth turned on and Azure Configured, then you'll get this as an option
Note: I've got OpenID connect with Azure configured, not azure natively, but it does work
5 Replies 5
ConnorL
Meraki Employee All-Star
Hey @beks88_ ,
During the Apple Automated Device Enrollment set-up process (i.e. when you're first setting up the device), we do not support using Azure AD and instead it'll fall back to using Meraki credentials (SM > Owners). Appreciate the different KBs make this a little confusing so I'll request some clarification is added here.
Cheers,
Connor
PaulF
beks88_
I'll try this, thanks
beks88_
This is working fine. The only thing I'm not able to test (since I have no access to customers Azure config) is the question if groups get synced to Meraki.
The log in redirection to Microsoft works fine here. Maybe you could update the docs to match the use case since they are still misleading.
One thing to note here; the customer I tested it with has also Android Enterprise (Meraki managed) active.
PaulF
@beks88_
We support groups syncing with:
  • Azure
  • SAML and
  • AD
