Set Devices Names of iOS Devices from CSV file?
Mark24
Hello
I am wondering if I have a csv file with a list of Serial numbers and device names is there a way to import that into the meraki to set the device names of our ipads?
3 REPLIES 3
Uberseehandel
I've had a quick look at what can be done in  the scanning API that I haven't explored yet. The device MAC seems to be used to identify mobile device locations.
So if you have the MAC addresses, then something is probably possible . . .
BlakeRichardson
Hi Mark
Not by default now, this would be a useful feature so I would submit a feature request by using the "Make a wish" button on the button right of your dashboard page.
www.btr.net.nz
Melissa
Meraki Alumni (Retired)
@Mark24 You can use the API to do this! Click on the "help" button on the upper left and select "API docs".
