Safari Activities
cKoppen
Safari Activities
I have some iPads locked down with MDM profile settings.
After installing Acrobat Reader, I'm trying to send a PDF from Safari to Acrobat Reader by touching the Activities button in Safari, but there are only default actions available, like "copy", "print", etc.
Usually Acrobat Reader would be accessible in the Activities menu after installing the app. Is there a setting that prevents this?
1 REPLY 1
Melissa
Meraki Alumni (Retired)
@cKoppen - There could be a few things going on here - I'd recommend opening a support case to be sure!
Is it possible you have a restriction set to "Disallow sharing of managed documents with AirDrop (iOS 9+)"?
That could be causing it...but support should be able to get a better idea of what's going on!
