SM Tags need updating
BlakeRichardson
These tags probably need reviewing updating, Apple renamed DEP to ADE years ago and where is the windows tag? As well as having K12 there should be a business tag.
Suggestions would be
Android
Apps
Business
ChromeOS
Education
Enrollment
iOS
iPadOS
MacOS
TVOS
Windows
Other
CarolineS
Community Manager
Community Manager
Thanks for the heads up, @BlakeRichardson! We will update the tags (aka “labels”) available in this forum soon!
Caroline S | Community Manager, Cisco Meraki
nbv
Great suggestions! I'd like to add another suggestion for Scripts.
@CarolineS
CarolineS
Community Manager
Community Manager
@nbv thanks! Do you think the existing "API" label should be changed to "Scripts", or does it make sense to have both "API" and "Scripts"?
nbv
I could see how both could fall under the same category. Maybe there's not enough posts about either to justify having two different ones as well?
Personally, I'd like to see them separated. When I think API, I think configurations or automation at an organizational level and connecting to other APIs. When I think scripts, I think device and software configurations. They also have their own separate menus in the Meraki dashboard.
