Office 365 and Exchange ActiveSync payloads
ConnorL
Meraki Employee All-Star
Hey Community folks! 👋🏻
With Microsoft recently depreciating Basic Auth for Office 365, those who are using Exchange ActiveSync payloads will likely experience authentication errors if they're not already using modern authentication.
A simple fix for this is to enable "Use OAuth for Authentication", this will prompt the user to authenticate using the modern method and allow the user to continue to use the native Mail, Calendar, Contacts, and Notes applications on iOS.
You shouldn't need to fill in the Signin URL or Token Request URL fields, as it'll prompt the device to auto-discover, however, if you do need these they can be found on your Office 365 admin console.
A small downside of this compared to basic auth, is that the end user must know the username & password of the O365 account they're authenticating, this is a limitation of using modern auth and is not something we can control on the Meraki end.
Meraki Support can assist if you have issues installing the payload, but once the payload is installed this is outside the remit of Meraki's control and you should direct authentication questions to Microsoft.
17 Replies 17
ConnorL
Josh3
We set up OAuth last week for mobile users, but many of them keep getting prompted every day to re-enter their password.  Is there a timeout setting somewhere that I need to look for that will extend this login period?
ConnorL
Hey @Josh3,
This will be configured most likely on the Office 365 end, the Exchange Payload has no capacity to define when a user must authenticate.
Do note however, that any time you make a change to a profile that contains an ActiveSync payload (even if the change isn't regarding ActiveSync) the profile is re-installed and the user will be prompted to reauthenticate. Therefore it's best to have the ActiveSync payload in its own profile, so that any other changes (such as WiFi, restrictions etc) don't require the user to authenticate.
PG01
Did you guys get around this? Looking to implement soon. Our issue is, folks don't know their passwords, as they are field techs.
Josh3
That's kind of my issue as well as the linemen don't keep up with their password.  It is strange.  Some folks it asks for password re-entry every day, others it's longer.  Some people never have an issue.  Newer devices seem to act better.
Chris16
Did you all ever solve this?
TreyGill
Hi thanks,
I am unable to get it set up. It will ask for admin approval. I am unsure how to set it up. I have now spent over a week on this. It keeps asking for consent admin permission and I do not want to give each user admin consent.
Is there documentation on how to set it up from beginning to end?
Regards,
Trey
praker
You should only have to provide admin approval once.  I recommend setting up the device for an admin first and when prompted provide the approval.  After that is complete, users should not receive the prompt.
Derf1
Thanks ConnorL for this helpful post.
So just to confirm, with OAuth enabled, the password push is basically meaningless right? (eg: users must interactively enter their password?)
We're in a similar situation as PG01, where our field users don't know the password to their mailbox, and everything is just pushed to their (shared) device.
Hoping there's a workaround where passwords can continue to be pushed even with OAuth enabled.
PaulF
Sadly, the authentication process is completely different for OAuth and requires user input... This can't be avoided.
Chris16
Hi there,
What did you all end up with for a solution for this? We are trying to use OAuth to streamline the setup on mobile devices of email and often times multiple times throughout the day the native apple mail app will lose connection where the user would have to go into the mail settings on the phone, tap sign in again and then access comes back but refresh tokens are not being issued successfully. We are stumped at this point.
Thanks,
Chris
pstokes
So the issue I'm having with this is it seems like anytime the device check ins with meraki it breaks the auth. If I go into settings and accounts it shows the account isn't authenticated. When you click re-enter password you don't have to actually enter the password it just does it's thing and closes.
To me this would feel like an issue on the meraki end? nothing is changed in the settings/profile so it's not re-installing that profile when it does a check in.
PaulF
Is your Exchange policy combined with other policies in the same payload? If so, every time you make a change to any of the policies in a payload, iOS will automatically re-apply the policy to devices, resulting in the exchange policy being re-applied, and the resulting password prompt
If not, raise a case, and ping directly either myself or @ConnorL and we'll take look
pstokes
No change in payloads, just seems to be as I stated whenever the device checks in it causes it to break.
pstokes
@PaulF @ConnorL just opened a case on it. Case # 09568723
Chris16
PaulF, I have had similar issues, even if the user is not getting a new payload they are required to sign back in from the account settings multiple times. All of the documentation I can find from Meraki's site seems to indicate that you don't need to enter any URLs after you check the box for OAuth enable but I don't have an answer for why it will prompt sometimes multiple times in the account settings. I have a support ticket open but have not received an official answer. I have also contacted Microsoft and have not received an answer from them yet either. Thanks for your time!
Chris16
Did you ever figure out how to resolve this? We are having the exact same issue.  What I don't understand is why the OAuth refresh tokens don't seem to be working because theoretically after the initial access token is received you are supposed to continue to get refresh tokens until the token is revoked.  My users are getting super frustrated because the mobile app doesn't stay authenticated. When you setup OAuth from the Meraki settings did you have to put in any URLs or did you just check the box to enable OAuth and then leave them blank. Also from the Azure/Entra side did you have to create an app registration or does it somehow autodiscover everything needed for it to work. Final question - our users are using the Native Apple Mail app as well as some using the Outlook app. Are there any differences that you have found with either app?
Thanks!
