MacOS - Enable Remote DESKTOP Command
Colin31
Has Meraki MDM implemented this command from apple
Use MDM to enable Remote Management in macOS - Apple Support
to allow apple macs to be accessed remotely using Remote Desktop tools on another computer without having to manually turn it on in system preferences for every mac.
Looking online it doesn't seem like this is a profile option that can be pushed out.
(this used to be possible via command tool using kickstart command but this has been blocked on new OS versions)
If so could you point me to where I find it as there doesn't seem to be any documentation around how to apply the command to an ADE managed Mac.
The meraki Remote desktop Beta is a little to unreliable and lacks some feature so I'd rather use apple's remote desktop tools to support the devices.
7 REPLIES 7
PaulF
Meraki Systems Manager doesn't use the inbuilt Remote Desktop capability for the client devices, as this is only available to Apple's own Remote Desktop (more about that here: https://support.apple.com/en-sg/guide/remote-desktop/welcome/Mac)
So users will still (and likely always) have to enable screen sharing (which isn't Remote Desktop) before admins will be able to remote in.
Colin31
Thanks for the update.
The implication from other MDM providers is that using this apple command allows screen sharing to be turned on remotely with out any end user interaction. This would save hours of time when support labs of mac's in schools by allowing the use of apple remote desktop
If this is not in the road map for implementation please could it be looked into.
PaulF
I read this through this again, and understand the utility of being able to enable / disable Remote Desktop, not just for you, but other customers too. Therefore, I've created a feature request for you.
Any update on this feature request?
Is there any update on this?
ArtM
I'm in a school setting and have been looking for an update as well. Seems other MDM's have this possible. I'll post what support tells me.
BlakeRichardson
@Colin31 This is only a command, you should be able to deploy it using the shell script option in systems manager.
The command I run via Jamf is
#!/bin/sh
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -specifiedUsers
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -allowAccessFor -allUsers -privs -all
