So this started last week. We had some issues a little while back and all the mobile devices have to be reset and re-enrolled. This is going fine and the fixed devices installed and configured all apps including Outlook correctly. Then at some point last week, the devices started removing and re-adding Outlook seemingly at random.
Now, several devices are just refusing to install it now. It shows a status of NotNow in the log on some of them when attemtping reinstall. Some will show it the install as successful but when you look at the app list for the device Outlook is listed as Version 0 with 20kb size and the status there will say Installing but never finishes.
Any ideas where to start with this? We took over this client not that long ago so I'm still learning all the details of the setup.
