Is there a way to change iPad owners in groups
Hulafish
Trying to find an easier way to unassign ipads at the end of a school year.  I can't find a way to do it in batches.  Is there some way to do this?
To clarify I was hoping I would check 10 ipads, and then just say unassign or something like that.  Not sure if I am just going blind and not seeing it but right now it is a pain as you need to click on each ipad individually and choose unassign.
Sorry if this is a silly one, any help would be appreciated.
7 Replies 7
I bet @BlakeRichardson knows the answer.
BlakeRichardson
Cheers for the tag @PhilipDAth  but I don't believe there is. I've double checked the devices and owners pages and I cannot find anyway of removing device owners in bulk, I've always had to manually make the changes.
That is the answer.   🙂
Hulafish
Unfortunately I think that is right.  This would be a very good thing to add.  Its ridiculously time consuming on a large reset which happens often for schools.  Seems like a no brainer.
cqlm
Thanks for bringing this up! Please know we truly value customer feedback and encourage you to share your thoughts with our team directly via the "Give your feedback" button (usually found at the bottom-right of the Meraki dashboard). The most requested features often make their way into development.
For more details, you can check out this article: Give your feedback
vassallon
I mean technically you should be able to download a list of owners and serial numbers.  Make your changes to owners and import the list back into Meraki and it would change ownership.
I'm having issues downloading a Current CSV for owners and devices to test this out. Not sure if it is a Meraki thing or an issue on my side.
CarolineS
Community Manager
Community Manager
Yeah teamwork!! 🙂
Caroline S | Community Manager, Cisco Meraki
