- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Importing App not working
Hi All,
I have been trying to import the app Scootle into my network. I can choose which VPP account to import from, and then I can select the app (there are 150 licenses available) but when I hit import Meraki no longer asks me to save and nothing happens.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, thanks. I tried this optuon and it still didn't do anything. I have now gone through the "add App" button instead.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
hi @BobMacco maybe if you can follow the link of below of one with the almost similar issue you may also be assisted
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@BobMacco I've used the import function a couple of times however I find manually apps has always worked for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your reply. when I click import I can then select the licensed iOS option and I can then choose my network and I can then also select the app I want to import. When I then click import after that the import window closes. What used to happen after that was a small window with "cancel" or "save" would pop up, then the new app would be in the list. The "cance" or "save" pop up now does not appear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@BobMacco in that case you will have to contact support team and sort out that issue for you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I know that sometimes when I add a new app, it doesn't always show up but if I scroll to the bottom of the page the save button is there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
