How to disable Ipads Cameras
NetAdmin1
I'm trying to disable the camera function on a group of Ipads that are managed with Meraki MDM. We have several types of departments and policies and we target them by using tags. I would like to accomplish the cameras disabling by using tags if possible. If anyone can point me in the right direction I will appreciate it. Thanks!
3 REPLIES 3
Inderdeep
Re: How to disable Ipads Cameras
@NetAdmin1 : Not sure but can you check this and disable this on your dashboard ?
Systems Manager/Settings/Restrictions/iOS & MacOS/Allow photo stream
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
Shany
1. Create a new Settings Profile first to apply different policies depending on the tag.
  Systems manager > Settings > [Create new Profile has new TAG]
2. Uncheck 'Allow use of camera' in the path below.
  [New Profile has new TAG] > [Add 'Restrictions'] > Cross-platform restrictions > Camera
3. Apply newly created tags to iPad that disabling camera use.
4. Boom!
BlakeRichardson
@NetAdmin1
