Device view -- new button "Unenroll Device"
alexis_cazalaa
just want to be sure about what it does.
thanks
MerakiDave
Meraki Employee All-Star
@alexis_cazalaa sorry I did not clarify, this will not remove devices from DEP, and only removes the MDM enrollment (profile, apps, settings) from the device itself, DEP is not impacted.
14 Replies 14
MikeMandalorian
This is another great example why there needs to be a Change Log  and Advanced notice before a feature like this is thrown out there. its like a Red Button  Ya don't know what it does but you REALLLLLY wanna push it to find out LOL
BlakeRichardson
One would hope it doesn't unenrol from DEP as that would be a nightmare if thats accidentally clicked.
alexis_cazalaa
@BlakeRichardson that's my main concern. that is why i need their definition for "Unenroll'
MerakiDave
@alexis_cazalaa You can safely click that unenroll button, and you'll get an "Are you sure" pop-up with the description "This will remove the management profile on the device and unenroll it from Systems Manager.  Are you sure?"
Hope that helps!  I do agree that this new button kind of silently showed up recently, and there should be a little "i" information bubble/popup to explain what it does.  Looks like there's no mention of it in the documentation yet here: https://documentation.meraki.com/SM/Device_Enrollment/Uninstalling_Systems_Manager_and_Removing_Mana... so I'll bring this up with the UI and Documentation teams.
alexis_cazalaa
hi, i already read the description. i need to know what "unenroll" means, is it just about deleting the client.
i don't think that would release it from DEP but i need to make sure.
MerakiDave
MikeMandalorian
@MerakiDave  All those options have now disappeared
beks88
same to me
alexis_cazalaa
MerakiDave
@beks88 @MikeMandalorian Give Support a ring, some of us are seeing those options, some a not, so something is out of sync on the back end between our different shards perhaps, should be a quick fix.
@alexis_cazalaa also wanted to make sure that clarification answered your question.
beks88
The magic buttons came back over weekend.
JoesTechRoom
So it sounds like this new "unenroll device" button does the same thing as the old "Remove" button that shows when you click the Edit details button at the top of the client page.  Is this true or is there some new functionality?
alexis_cazalaa
"Remove" just removed the device from the client list... this one adds profile removal.
cqlm
At this time it is only supported for iOS/iPadOS. Furthermore, it is briefly mentioned as a method in the following KB for specifically iOS/iPadOS:
As Dave mentioned this will only remove the management profile. To unenroll ADE devices please refer to this section:
https://documentation.meraki.com/SM/Device_Enrollment/Uninstalling_Systems_Manager_and_Removing_Mana...)
