Auto install Rosetta 2 on M1 Macbooks
MarkusK
Hi guys,
I have got my first M1 Macbook in my org and noticed that the Meraki Agent will not install unless you have Rosetta 2 installed on the Macbook.
As I DEP enroll my Macbooks I really would want to have it automatically install Rosetta 2 so that the Agent can run.
Have any of you guys managed to solve it?
I have tried adding:
/usr/sbin/softwareupdate --install-rosetta --agree-to-license
as a Command Line to run after one of my apps install
and I have tried to make my own .pkg-file with no payload and only a post-script that runs the same command as above.
But none of them seems to work for me, Rosetta 2 never manages to install and the Meraki Agent never comes online.
2 REPLIES 2
BlakeRichardson
@MarkusK  Try   sudo softwareupdate --install-rosetta --agree-to-license
That is what we use on Jamf and it works ok, have not tried the command you have provided.
www.btr.net.nz
Hey @BlakeRichardson,
I tried that too now.
Created a pkg with a preinstall-script that just run
I then put the pkg in a dmg and uploaded to Meraki as a custom app and tried to install it but Meraki just reports the install as failed and Rosetta is not installed.
