Pushing Microsoft Outlook
ITGuy1024
I am having a slight issue pushing Microsoft Office for Android. The app pushes to the device but I seem to be missing a certain switch for setup.
I have these key settings configured so far.
com.microsoft.outlook.EmailProfile.EmailAddress
com.microsoft.outlook.EmailProfile.EmailAccountName
com.microsoft.outlook.EmailProfile.ServerHostName
com.microsoft.outlook.EmailProfile.AccountDomain
When I open the Outlook app on the mobile device all the fields are filled out as they should be except for "Domain\Username" and "Password".
I am able to type in the password as expected but I am not able to type in the domain\username and I do not see a key setting for it in the App Config. So I'm not sure what key value I need to use for the domain username field.
Thanks in advance.
ITGuy1024
It looks like this is the key to supply the domain\username field.
com.microsoft.outlook.EmailProfile.EmailUPN
2 REPLIES 2
ITGuy1024
FernTech
Hi I'm fighting this same battle and can't find a concise list of all of the Keys, Types and Values, would you mind sharing where you found them?
thank you!
