Has anyone configured app settings for MS Outlook to be pushed out with MDM? I am looking for a list of Keys, Types and Values available.
This should be what you're looking for: https://technet.microsoft.com/en-us/library/mt813789(v=exchg.150).aspx
hi,
I'm also trying to configure the application. the link in the reply does not seem to me to answer the question.
Does anyone have any other suggestions?
Best regards
@Aondio_Carlo What info does the link not provide that you're looking for? It includes all of the keys that you can set in MDM to configure the Outlook app automatically for users.
I couldn't find the initial setup keys for mail server, domain, etc...
It looks like Microsoft rewrote the article I originally linked to. This one provides the correct config settings: https://technet.microsoft.com/en-us/library/mt829322(v=exchg.160).aspx
Thanks! Better link.
I have read carrefully the KB for Outlook android app settings....but in meraki the apps Microsoft Outlook does not support any setting :
The key form can only be filled by a list value.....
You confirm ?
@MRCUR Thanks for flagging this/me 🙂
I'm looking into it with the team...will have an update soon.
I'm out of the office but will try to post asap!
Ok thank you, I'm waiting....:)
it's working now 😉 you can retry, i add the return of the support.
It's working for us.
Yes, I confirm it's working now....:)
I still don't see the supported setting for IOS. Only Android
@Larry managed app settings for ios can be pasted in the key value fields. They aren't made automatically searchable like they are for some Android apps (where the database of settings can be pulled by dashboard).
I had this working for a while. Now, Outlook IOS setting are not passing through.
Is there any standard format to configure this for outlook.com accounts? I'm trying to use the devices owner credentials to configure the account on the Outlook app and used the keys from the Microsoft KB article, but I'm missing some fields on the app. It's still asking for description and password.
So far I have
Key 1. com.microsoft.outlook.EmailProfile.EmailAddress Type: Owner: Email
Key 2: com.microsoft.outlook.EmailProfile.ServerAuthentication Type: Owner: Email
Key 3: com.microsoft.outlook.EmailProfile.EmailAccountName Type: Text: Value: Outlook Email
Key 4: com.microsoft.outlook.EmailProfile.EmailUPN Type: Owner: Email
Key 5: com.microsoft.outlook.EmailProfile.ServerHostName Type: Text Value: m.hotmail.com
key 6: com.microsoft.outlook.EmailProfile.AccountType Type: Text Value: BasicAuth
Has anyone managed to get this working?
I cant.
I have all the settings set as per the post above and tried various other variations too after using the referenced webpage, but all i get within iOS settings > Device Management is Unknown Payload against Managed App Settings.
And when i open outlook im just prompted for an email address to start configuring an account.
Is anyone try to configure two exchange account on outlook application via mdm settings ? the application allow multiple account....
Looks like you are missing:
com.microsoft.outlook.EmailProfile.AccountDomain
