Meraki switch’s PoE issue.
Babera
6 of our switches lost all PoE capabilities 11 hours ago despite showing everything as working on the Meraki go dashboard. We have done all troubleshooting currently possible for us and still no PoE to devices or Cisco phones
Internet is up and running no issue but still doesn’t provide PoE to devices.
What would be causing this issue?
35 Replies 35
Soichiro-Ono
Hello.
Do you have any history of updates? There is another case of PoE going down during a similar period.
What is your GS firmware version?
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
Babera
There is no firmware current it’s saying Not running configured version
ArtMarshall
Meraki Alumni (Retired)
We are currently investigating a firmware issue that affects PoE performance on GS switches. Please open a support case in the app and DM the case number to me.
Thanks,
Art
ASCOA
We are having the same issue. Opened case number 09424332.
It started yesterday 03/16/2023. Unit is GS110-48P with firmware GS 15.21. Do you have an ETA on a fix? Thanks!
ArtMarshall
I've added your case to the support queue. Our support team will reach out with a resolution.
ASCOA
Thanks. I see now "Not running configured version" under Firmware. Can you update on the solution? Thanks!
ArtMarshall
Absolutely. The short term solution is a firmware rollback while we determine a longer-term solution. The rollback will restore PoE functionality.
The support team will contact you soon with next steps.
ASCOA
Great! I am assuming that your side will excecute roll back? What is the ETA on the process, and what version is the firmvare that I should see? Also, should I restart the device at some point or this will happen automatically?
ArtMarshall
Yes, our team will contact you and execute the rollback once you given them permission to do so. The device will reboot when the firmware update is complete.
The rollback firmware version is GS 14.33.1.
Babera
Am still having and issue here is the case number 09418497
ArtMarshall
Thank you - I've added your case to the support queue.
JRS1
Meraki Go Case 09427467
please fix it asap!
ArtMarshall
We've added this to the support queue. Thank you!
MiriamK
@JRS1 the team was able to update your firmware earlier today, and you should have PoE working normally. Just let us know if you're still seeing issues. Thanks again for your patience!
Miriam Kung
Cisco Meraki Product Marketing
JRS1
worked - thanks.
We still have one switch offline at the customer's, I'll get in touch as soon as it's back with us and we have to repair it as well.
best wishes from Hamburg
JRS1
BSE
I have exactly the same problem since 03/16/23 no port delivers POE on five GS110-48P all have also the firmware GS 15.21.
All my telephony is out of order. I need to find a solution urgently.
ArtMarshall
We have a resolution for this issue. Please open a support case and provide us with the case number (either here or via help@meraki-go.com) so that we can ensure that your issue is addressed.
OlegP
Hey Art, we got a customer that's affected with this issue. I've just created a case number 09425285. Are you able to provide us with a fix ASAP? Since they've been down for quite a while.
Thank you.
ArtMarshall
I've added your case to the support queue and our team is actively working through the list!
BSE
I have open a support case with number 09429899, can i have a repons asap
ArtMarshall
We've added your case to the support queue. Thank you!
jakster145
We have the same issue with a GS110-8P. Switch works, PoE doesn't.
Firmware is GS 15.21
Opened case: "Meraki Go Case 09426583"
I'd be happy to roll it back myself but I can't find that feature anywhere!
MiriamK
Thanks @jakster145, we'll make sure you're added to the support queue! They'll need authorization from you to rollback to the previous firmware version - the process is fairly quick and the switch will restart into the previous firmware version.
cc @ArtMarshall
Miriam Kung
jakster145
Thanks very much - just let me know how to provide authorization. I can do it now if you like.
-JAC
Stech
our switch has stopped working - no poe network down - is there a way to expedite this ?
ArtMarshall
Do you have a case number? The support team is working through these issues as quickly as they can.
If you can share your case number, I can make sure that it's tracked against this issue.
Stech
no, where do I submit the case?
ArtMarshall
Here is some information on contacting Meraki Go support
Stech
it says i have an email account - but when i try the password reset doesnt send a reset link ? can you assist? Support@stech.me is the email
MiriamK
@Stech we'll have someone on the team reach out to help you get logged back in + resolve your PoE issues. Many thanks for your patience!
Miriam Kung
Stech
thank you
MiriamK
@Stech it sounds like our team is having trouble locating your Meraki Go account with that email.
Would you mind writing into merakigo@cisco.com OR sending us a note through our form (here's the contact form link) so the team can dive in and help you get sorted out? Thank you!
Miriam Kung
Stech
ok, I've done that
Stech
no one reached out, this is still an issue - i have the switch off the rack and the serial number - but the app states that the email is in the system,but I'm not receiving any logon reset info.
MiriamK
@Stech thank you for contacting our team! It looks like the team was in touch earlier today - they'll follow up again from the info you provided to help resolve any issues. Much appreciate your ongoing patience.
Miriam Kung
