Creating L3 interface on MS225
mhurley131
I am trying to create L3 interfaces on a MS225, but am getting the following error:
"This switch does not support OSPF routing".
The switch does not support OSPF, but it complains that it needs the OSPF commands in the POST.     Is there another syntax I should try?
I have tried the following:
"name": "L3 interface",
"subnet": "192.168.1.0/24",
"interfaceIp": "192.168.1.2",
"multicastRouting": "disabled",
"vlanId": 100,
"defaultGateway": "192.168.1.1",
"ospfSettings": {
"area": "0",
"cost": 1,
"isPassiveEnabled": true
"vlanId": 100,
"ospfSettings": {
"area": "disabled"
Inderdeep
@mhurley131 : Can you check this
https://developer.cisco.com/meraki/api-v1/#!update-device-switch-routing-interface
Regards/Inder
www.thenetworkdna.com
Ryan_Miles
try this
"area": "ospfDisabled"
Bruce
If it is "ospfDisabled" then the notes on the API reference need some clarity as they state, "The OSPF area to which this interface should belong. Can be either 'disabled' or the identifier of an existing OSPF area. Defaults to 'disabled'."
Ryan_Miles
agree the notes should clarify if OSPF is not enabled already on the network then the call requires ospfDisabled vs. disabled.
i'll report this to the API folks for confirmation and fixing.
