Cisco Meraki and DNA-Center Integrations
ToryDav
I hope I put this in the correct location. I am trying to understand if this integration is possible, or road-mapped, or if it was abandoned.
Inderdeep
@ToryDav : Not seen anyone deployed yet, But check here under ( Search for "Integrate the Meraki Dashboard")
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna...
Regards/Inder
www.thenetworkdna.com
6 REPLIES 6
Inderdeep
Regards/Inder
ToryDav
@Inderdeep I will happily try it. I did find the info how to do this thanks to you. I will report my success or failures here.
Inderdeep
Sure let us know as well..
Regards/Inder
ToryDav
Fantastic, I followed the steps found in the solution provided by @Inderdeep and was able to add my Meraki devices into DNA-C sites inventory.
There are a few product types that didn't appear though, but what I really needed / expected to come over has, so this is a win for me.
More testing to come.
sungod
Not tried it recently, but with an older release of DNAC I added a test organization to see what it was like.
Found it extremely limited, then when I removed the org from DNAC, DNAC didn't clean itself up properly (no impact on the org itself.)
I think the latest versions of DNAC allow some basic provisioning of MR devices to assign SSID(s) defined in Dashboard, but beyond that I believe it's still very limited.
ToryDav
Thank you, this is good to know!
At the moment, I'm not really looking for a way to push configuration although it would be a nice to have. At this time I am only looking for up/down monitoring and network visibility, a way to consolidate my Catalyst + Meraki into a single dashboard (DNA-C). Getting these into my DNA-C Sites Hierarchy would just be nice.
Telemetry information would also be nice.
