I was looking to better understand client connections and to track connections by SSID, but when I examined the syslog for a given AP I didn't see any information that identified the SSID and client was connecting to. Where might this information be available?
You can check it on Network-Wide > Clients page.
Thanks, but I need to be able to integrate this with a partner application. I can’t use the following endpoint at scale, because I’d consume the Dashboard API rate limits for this one endpoint across thousands of networks. I’m wondering why the SSID is in this events endpoint and in the Dashboard but not in the Syslog.
The rate limit is per org. If you use the API across 10 orgs you could do up to 100 API calls per second.
I’m very aware of this. The problem is that this is a per-network API endpoint, not a per-Org endpoint (hence the can’t scale).
Hi @Prodrick, can you clarify what you mean by "connections"? I'm wondering if you mean this in the sense of "connection events" or "connected sessions" or perhaps something else.
Thanks @John-K . I’d like to be able to follow which SSID’s client connected to, or tried to connect to. In the syslog I can see everything related to specific APs, but I don’t see and can’t correlate those to which SSID. Does that make sense?
