hi all ,
can someone help me what this information below means?
Cisco Meraki products are built from the ground up for cloud management, and come out of the box with centralized management, layer 7 device and application visibility, real time web-based diagnostics, monitoring, reporting, and much, much more.
Solved! Go to solution.
It's one of the big advantages of Meraki. It was built from the ground up with cloud management in mind.
I could go on.
that it needs cloud connectivity. you manage all devices in one cloud portal. and that it analyses traffic not only the ip but also give you info what applications run in your network.
yes thanks alot
Hi
Well these are some common features of Cisco Meraki Solutions.
Zero Touch Provisioning
Dashboard - Single Pane of Glass
Centralized Management
Various other features of solution....
I could go on.
