Hi RaphaelL,
(1) New Look
The new Meraki dashboard UI and login page will be rolled out to all users globally on June 11, 2025.
To explore the new look, simply login to the Meraki dashboard – no action needed.
Updates to the Meraki mobile app will start a gradual rollout to users on June 11, 2025. Download or login to the Meraki mobile app for iOS and Android.
(2) New feature - Cisco AI Assistant - https://documentation.meraki.com/General_Administration/Cross-Platform_Content/AI_Assistant_-_Public...
(3) The fix should have been deployed yesterday.
As CarolineS mentioned, the workaround should work - The support center can be accessed by modifying the URL to /manage/support at the end of a network URL
If you have any questions, please don't hesitate to contact us.
