- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
No MSP in Dashboard after SMS 2FA
Hi there,
I got the issue that I can't see the MSP Portal in my Dashboard after login into a companies dashboard. Before enabling 2FA it was always over the "Network"-Choose dropdown and I was able to switch to another companies dashboard without the necessary of login again and then choose the company. Is there any possibility to get this working again with the use of 2FA?
Thanks!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Something is not right. When I enabled 2fa I still had the same MSP view with multiple organizations. I would contact support for help and did you turn it off and get MSP view back?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@ViragoRider As mentioned contact support, I have MFA and I can see all of the organisations I belong to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi BrandonS,
I tried turning it of and got my view back, but if I turn it on again it's the same. I will contact the Support. Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am having the same issue. 2FA was enabled years ago.
Waiting on support to.
