Per-device licensing and MX warm spare
Has somebody already tried to convert to the new licensing model in an org that has MX‘s in a warm spare environment? I just did and Dashboard is yelling at me because I seem to have an unlicensed device: my primary MX from that warm spare (interestingly enough, because this one has always been licensed).
The documentation and FAQ still clearly state:
Do I need duplicate licenses to cover my security appliance in a warm spare configuration?
A: No, if two security appliances are in a warm spare/HA configuration licensing is only required for one of the two devices. The only additional cost of a warm spare configuration is the redundant hardware.
I guess / hope that this is just something that hasn‘t come up yet but something seems to be utterly wrong in this case.
Accepted Solutions
Re: Per-device licensing and MX warm spare
Update:
I just called support (which is possibly what I should have done in the first place) and they were very helpful (as always).
It seems to be only a cosmetic issue within Dashboard that is currently known and will be fixed soon automatically.
Just leaving this here in case somebody else is also running into this.
6 REPLIES 6
Can you show what your license page looks like
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Licensing has not been an issue with the old model because of the warm spare configuration. Looks like that‘s not the case anymore.
Agree that needing two licenses seems wrong to me as well. Part of the deal with warm spare is that you've got two devices, but only one is ever active. If only one is ever active at a time, then you're supposed to only need a single license.
That‘s what the documentation clearly states:
Only one license is required for an HA pair. The warm spare unit does not require a separate license. Alerts for Warm spare failover can be configured on the Alerts and Administration page.“
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
A: No, if two security appliances are in a warm spare/HA configuration licensing is only required for one of the two devices. The only additional cost of a warm spare configuration is the redundant hardware.“
https://documentation.meraki.com/zGeneral_Administration/Licensing/Meraki_Licensing_FAQs
Update:
Have they corrected the cosmetic issue with the MX HA pair in Dashboard?
