“Encryption not supported on this firmware” error when adding a syslog server
Tyler_Gunn
Hello Meraki Community,
I’m running into a puzzling issue on my network. I recently tried to add a new syslog server IP under Network-Wide >  General. Even though I’m not intending to use encryption (just standard syslog), I’m getting an error message that says:
Encryption is not supported on this firmware version.
Has anyone else seen this before? My understanding is that the firmware shouldn’t care about TLS or encrypted syslog if I’m just specifying a basic (unencrypted) syslog destination. I’ve confirmed:
  • The syslog server is listening on the default UDP port 514.
  • I’m not checking any boxes or toggling any settings related to secure syslog/TLS.
  • The firmware on the Meraki devices is up-to-date (as far as I’m aware).
Despite all that, it refuses to accept my new syslog server entry and keeps throwing this error. Is there a specific firmware version that introduced (or removed) support for secure syslog that might be confusing here? If anyone has run into this “encryption not supported” issue or has ideas on how to resolve it, I would really appreciate the guidance.
Thanks in advance for your help!
ConnorL
This now should be resolved @Tyler_Gunn, if you continue to experience any issues please do inform Support. 🎉
12 Replies 12
Mloraditch
There is a new(ish?) option in the GUI for TLS for syslog:
I don't look at that field often, but often enough that I think I'd have seen it before. The documentation page also doesn't  mention it yet. I suspect they are in the middle of rolling this feature out and it will only work on newer models or firmware and perhaps the gui stuff isn't working right. I would call support and make them aware.
ConnorL
Hey @Tyler_Gunn ,
I'm able to recreate this on my personal network, can you raise a Support ticket so this can be correctly tracked?
Cheers, Connor.
Ryan_Miles
Seeing the same here. Also see at least one Support case opened today on it. I would suggest opening a Support case to get more evidence of it occurring.
RaphaelL
Great to know that Secure Syslog is in the work !
Jim_Benson
i didnt make any changes and when i got to page it said i had to save, i didn't make any changes! was going to try to enable remote login. i kept hitting cancel. but it keeps coming back with encryption error. in my lab i deleted the 2 syslog servers and the issue went away. but now i cant add syslog servers without getting error message.
Jim_Benson
working properly now,  Thank you
Ryan_Miles
Eng is working on a fix.
gurugrox
Thanks for the information, I was just about to do a firmware update on Meraki Switches & Access Points, and when I went to apply the settings to upgrade now, I received the same message.  Can you estimate how long this will take to fix?
ConnorL
I'm able to save changes now on the Network-Wide > General page, and also schedule a f/r upgrade. Would you mind testing this again now @gurugrox ?
Tyler_Gunn
It is now working for me.
gurugrox
It now works for me as well.  Thanks!
ConnorL
