Clients Page Freezing/Slow
jumbojake
Has anyone else noted that the new Clients page (Network-wide > Clients) is clunky to the point you're barely able to use it? Mine is constantly freezing and requires me to reload the page. I don't have this problem when I revert to the old version.
5 Replies 5
Has anyone else noticed that the new page is slow?
I fixed the question for you. 😉
I've been having random functionality issues.  I have had to revert to the old version to perform certain tasks, and then revert back.
They'll get there.
I've just developed a new product for the marketing team.  "Meraki Patience".  The bad news would be that it has a 6-month lead time.
Mloraditch
The new pages consistently work less quickly and less often than the old ones. It's incredibly frustrating. If they spent as much time making the pages pretty, as they do adding features we'd have old working pages with tons of new features.
EAzevedo
Hi @jumbojake ,
Thanks for your post and apologies for the inconvenience. I was glad to read that you found a work-around (spot-on).
Based on your description, I believe it aligns with an issue we were having which is marked as solved around 2h ago by our development team.
Could you kindly:
1) Check if the issue remains?
2) If yes, raise a case with support so we can investigate further?
Thank you have a great day ahead of you.
redsector
Horrible slow is the "Network-wide" - "Clients" page. You can´t work with that.
